How do I add a sum/total cell to a table through API?
I've got code that creates a drawing, inserts views, and inserts a table (not excel based) and adds a row to the bottom... now i need it to add a sum/total cell to a column, but i can't find how, or if it's even possible...
anyone done this successfully before?
RE: How do I add a sum/total cell to a table through API?
Are you creating a new column?
I don't know about in Code - But I assume you know how to do this in SW otherwise? If not see SW05 What's new manual, it tells you there.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Use a loop which calls TableAnnotation.Text (Row, Column) at each cell to retrieve its value.  Convert to the required number format and add to the total.
I suppose thats the only way to do it. seems rediculous though, that you can't just change the property of the cell to 'sum/total' like you can when viewing a drawing. it would be so easy to program....
Did you check out the What's new in 05? It explains the entire process there, then you can figure out if you can do it in code.
Chapter 10 - Page 10-16
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
i hadn't read that, but i already knew how to do it through those checkboxes... but i can't find any reference to sum cells or total cells in the object browser, or searching in the API help.
could it be part of another reference that i don't have installed? how would i know what i need activated?
as far as i can tell, it's not possible to make a cell a sum/total cell through API...
Also, i've tried recording a macro making the change. all i get (as I usually do) is a program that selects my BOM.
why is the macro recorder such a piece of crap?
there were quite a few things i tried recording macros for and ended up with a bunch of code that was all 'SelectByID2' lines. i can't remember at the moment if it was all BOM stuff, but it may have been.
i'm quite convinced this isn't built into the API. should be, though.
The macro recorder can only track actions, not logic.  You need to add the logic yourself.  The functionality to sum columns/rows is already built into the api.  For example, to sum column 3 of a rev table:
Option Explicit
Dim swApp       As SldWorks.SldWorks
Dim DwgDoc      As SldWorks.ModelDoc2
Dim swSheet     As SldWorks.Sheet
Dim swRevTable  As SldWorks.TableAnnotation
Dim Msg         As String
Dim nRow        As Long
Dim nCol        As Long
Dim nSum        As Long
Sub Main()
    Set swApp = Application.SldWorks
    Set DwgDoc = swApp.ActiveDoc
    Set swSheet = DwgDoc.GetCurrentSheet
    Set swRevTable = swSheet.RevisionTable
    nSum = 0
    nCol = 3
    For nRow = 1 To swRevTable.RowCount - 2
        nSum = nSum + CLng(swRevTable.Text(nRow, nCol))
    Next nRow
    swRevTable.Text(swRevTable.RowCount - 1, nCol) = CStr(nSum)
End Sub
that's what i've done, but it worries me. if the table gets updated (which is possible) that total isn't dynamic, where a sum/total cell is.
The lack of dynamic update is the biggest problem with the custom table.  The only way I have solved it in the past is by converting my code to an add-in that runs whenever someone loads / changes the active window to a drawing.
Evan T. Basalik, MCSD
It's all about prioritization...
Here's a zip file from solidworks. i don't know why i didn't find this earlier, and now we've restructured the drawings and no longer need the calculated cells, but if anyone else needs some help here, this file includes a nice powerpoint slideshow and some useful programs to cause calculated cells to refresh on every rebuild. i haven't read the code, so i can't vouch for it, but they do claim to have code to help with this.
http://www.solidworks.com/downloads/API/Downloads/00000/0300s/0311/Automating%20and%20Customizing%20New%20Bill%20Of%20Materials.zip
