Continuous cast iron cleaning drum - supplier -
Hi all the comunity
I have a problem to solve urgently .
I need to remove the carbon material adherent on cast iron pieces , I know the shot blast process but our client don't like this process due to the hight cost of maintenance for this machine.
They whish have a simply process without any consumable material and with a ligth cost of maintenance!!!
the rating load is 4 metric tons / hour with apparent density 2mt/m3.
I think we can use the principle of the collision between the thimbles into the drum. This action separates the carbon from the iron. The residues are discharged through small
openings along the surface of the drum, and the thimbles through the opposite side of the entrance. This is a continuous process, so there is no a storage silo for dirty thimbles, they are fed and discharge by means of belts
conveyors.
But I haven't any supplyers of this equipment , can you help me , it is very important for us .
Bilou ( mechanical eng.)
conveyors.
RE: Continuous cast iron cleaning drum - supplier -
http://www.didion.com/index.htm
Anecdotal:
Here is the unglamourous end to a CI tumbler where I started my career. This area was so noisy that to have a conversation you walked up and butted heads.
This is the smallest of 3.
h
I will search in your direction , Didion is
perhaps the leader of a closed manufacturer of this equipment , but I hope having another challenger manufacturer , Only to improve and compare technology and pricing , and after sale services .
one more , thanks for your help and if I can give a hand , I will be very happy
Bilou
http://www
[code]
http://www
[code]
_______________________________________
Feeling frisky.........
www.tailofthedragon.com
