Sensor installation on 2" High Pressure Piping
Dear All,
I need your advice regarding installation of sensor on 2" high pressure (10000 psi). Is it OK if we just drill some hole and make a thread match with the sensor ? or there is some specific requirement for this.
RK
RK
RE: Sensor installation on 2" High Pressure Piping
THAT IS DEFINITLY NOT OK....
If you're talking about drilling a hole in the side of a 2" pipe and tapping it to screw in a threaded pressure sensor for a 10,000 psi system.
You need to use properly installed fittings designed for the pressure rating of your system.
You scare me,
NozzleTwister
Houston, Texas
