Custom BOM field
Custom BOM field
Our title block had 2 lines that we shortened to 1 line. One was File name ($PRPSHEET:"SW-File Name), the other line was Configuration name ($PRPSHEET:"SW-Configuration Name"). We put the 2 together to creat 1 single line that is File name - Configuration name ($PRPSHEET:"SW-File Name"-$PRPSHEET:"SW-Configuration Name").
Original Title Block Example:
31005-01P (file name)
1 (configuration name)
New Title Block Example:
31005-01P-1
(very simple)
The problem is that I cannot find out how to put 2 fields together in the SW BOM (not Excel BOM). For 2 columns, simply use "SW-File Name" for column properites, and "SW-Configuration Name" for the 2nd column. BUT I cannot put these 2 columns into 1.
Any suggestions?
Flores
31005-01P-1
(very simple)
Any suggestions?
Flores
RE: Custom BOM field
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
$PRP:"SW-File Name"-$PRP:"SW-Configuration Name"
instead of
Flores
