Making a helix sweep along a guide
I am trying to make a helix sweep along a guide. I am trying to show an 11" long spring wrapped around a bag holding it on. I know how to do a helix and a spring as usual but not to make it go around in a circle..
RE: Making a helix sweep along a guide
Or you could leave it & simply add a cross-reference to the post you found your answer in.
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
I used the spline on surface button and drew a spline on a solid "ring" and then sweep cut. I didn't like the look of it so I just deleted it. So if any of you know how to do this. Please englighten me. Thanks!
2005 (I think...maybe 2004) introduced a new sweep option in which the profile can twist along the path. This should get you exactly what you want.
Here is what I have done before:
Create my path (centerline of the helix).
Create a sketch with a plane normal to the end of the path. This sketch is just a SIMPLE line going from the path the the center of my profile.
Sweep the line along the path with the twist option to get a auger like surface.
Now, use the edge of the auger as the path for my helical sweep.
This way, my profile is always normal to my helical sweep path.
