PanelView Plus 1000 Alarm list not working ???
Last remainning issue on this project. Now i know my tags are comming in the touch screen.
What have I forgotten to do^
What I have done so far.
Configured the alarm setup (triggers and so on)
Pointed that to the alarm list page
Tags are all bits so I put bit for trigger type.
In the message i put trigger value to 1
Triggers and messages are all there.
Did a page with alarm list.
Why is no alarm being generated.???
Thanks ray
RE: PanelView Plus 1000 Alarm list not working ???
Try changing the trigger type from 'bit' to 'value'.
The following is from the Rockwell Knowledge base,
E26036864:
Problem:  Alarm trigger causes error when project is run.
Cause:  Alarm trigger is set to bit triggered in Alarm setup, and trigger tag is digital. RSView ME is expecting Block tags when it sees bit triggered selected.
Verify:
Cure:  If you are using digital tags, select Value as the trigger type in Alarm setup. This scenario is common when using OPC to communicate with a device, since OPC does not support Block tags.
Yep that did it
Thanks NewBeaver
