Disappearing menus
Disappearing menus
Disappearing menus
Is there any way to keep the interactive menus (like the 'View Manager' menu) from disappearing behind the main window (WF2)?  Digging them up after they bury themselves every few minutes is getting old.
Chris
RE: Disappearing menus
On Windows, use ALT+TAB to bring the hidden menu back to the front.
That's what I've been doing, but I was hoping that there was some way to keep them from disappearing in the first place.  Some kind of 'always-on-top' setting in the config.pro file that I was unaware of, or something like that.  Thanks for responding though.
Chris
If your video card supports 2 monitors (and with the proper Windows XP display setting) you can slide your menus and model tree, etc. over onto the adjacent monitor.  That's what we do.
We use pro/2001 with Windows XP, but I would assume you could do the same with WF2.
SrG.
That sounds like a great way to fix the problem and double the working screen area at the same time, however, I think I would have better luck asking the IT dept. here for a 2nd head.  :)
I was assuming that there would be a simple fix for such a simple problem, but it's not looking that way.  I guess I'll have to keep 'alt-tabbing' for now.  Thanks for your response SrG.
Chris
It is some annoying behavior (maybe WF3?).
I have found that using MMB to accept default picks vs. actually hitting the OK button will help; the dialogs stay on top.  Setting colors and appearances, after entity selection is the one that comes to mind.  There may be others.
You should be sure to report this to ptc to make sure they address the issue.  It seems this must be very irritating to everyone if you are continually having to hit "alt-tab".  And surely it needs to be fixed because an unanswered dialog box needs to remain on top until it has been answered.
Maybe a hotkey or a menu button could be created to make it easier than always having to hit "alt-tab".
We had so many layoffs here that everyone here using pro-e got an additional monitor and we can slide things over to an adjacent monitor (fewer window get stacked on top of each other).  It may not be an option for you, but once you get used to 2 monitors, I wouldn't want to go back to a single.
regards,
SrG
