Backfill and retaining walls
What is the maximum height of backfill or grade height on an exterior wall before you have to use conc. block or a poured conc. wall?
I am doing plans for a raised cottage and I don't have a code book at hand right now.
Thank you.
Thank you.
RE: Backfill and retaining walls
There are many inexpensive retaining wall programs on the web, including retainpro that provide the necessary design info and calc quickly and efficiently.
Good luck.
