Pressure tubing and structural tubing
    I am looking for infomation on the following topic for a college report
    1. Production of steel pressure tubes -- i.e. welding and fabrication
    2. Tubes under extreme external/interior pressure -- i.e. isotropic loading.
    3.  Requirements and effects of underwater welding (on steel tubes) at extreme cold temp. and high pressure.
    4.  Failure of steel tubes and prevention of failure under high pressure-- i.e. weld induced residual stress, fatigue,     corrosion.
    5.  Additional considerations of structural pressure tubes at high pressure -- i.e. what happens if I load the tube.
Thanks a lot
