Can a lead crown be applied with a hob?
On a simple involute spur gear - I was under the impression that in order to apply a crown in the lead direction it is necessary to use a grinding wheel and either plunge the wheel into the part as it traverses the face width or etc. But is it possible to get a lead crown using a hob cutter?
Thanks.
Thanks.
RE: Can a lead crown be applied with a hob?
Would you happen to know the best surface finish that is achieveable by hobbing using the best equipment available today?
