Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I just wanted to say that you guys RULE, a million thank you's to whoever created, and/or manages this site. KEEP UP THE GOOD WORK..."
Geography
gpape (Mechanical)
1 Jun 05 15:10
Does anyone have any comments or history with these materials used for large, thick (14") ASME tube sheets?  Design 350 PSI @ 500°F - MDMT (-)20°F? I am interested in the toughness and the best material I can get.
Helpful Member!  metengr (Materials)
1 Jun 05 15:26
We have SA 350 LF2 forgings for our older high pressure and low pressure feedwater heater tubesheets. No problems to speak of - it is a very common forging material.
Today, I would probably recommend going with SA-765 Grade II only because it applies directly to carbon and low alloy steel forgings for use in heat exchanger and feedwater heater components, like tubesheets.
stanweld (Materials)
1 Jun 05 15:57
SA-350 LF1 and LF2 has a long history in both the petrochemical and power industries in similar thickness and thicker tubesheet applications. The primary differences between the two specs are SA-350 LF2 is made to fine grain melting practice and impact testing is required while fine grain melting and impact testing is optional for SA-765. There is also a subtle difference in impact test location for your thickness.
metengr (Materials)
1 Jun 05 16:11
Stanweld;
Impact tests are required in ASME SA 765 - Table 3. The purchaser can recommend other test temperatures as optional but you need to conduct impact tests. For Grade II the impact test requirement is 12 ft-lbs at -50 deg F.
gpape (Mechanical)
1 Jun 05 16:28
Thanks metengr!  You have stated the same evidence that I had originally come up with. The only draw back that I can see, is the addition of Ni, Cr, Mo, V, Al & Cu to the chemical analysis. I do understand that this makes it tougher and more weldable that LF2. I also am happy with the required testing, since I have required even more tests than SA 765 requires when I bought SA 350 LF2.
1 Jun 05 16:48
metengr,
Oops, misread 6.1. Going senile.
metengr (Materials)
1 Jun 05 16:54
Stan;
Been there and have done that many times. Time for a beer!
unclesyd (Materials)
1 Jun 05 17:52
stanweld
I call that a "senior moment" and it seems to happening more frequently.
Close Box
Join Eng-Tips® Today!
Join Us             Close
