Two Hydraulic Motors, controled by one Hydraulic Pump.
I am posting this for someone else. Here is the application:
I have a fixed 23 GMP pump, 3000 PSI
I am running 2 hydraulic motors, both reversible.
I need one supplied at 15 GPM
I need to adjust the flow to the second motor for speed control.
I think I need a diverter valve to split the circuits, priority circuit @ 15 GPM. Then run the auxiliary output thru a flow control valve.
Then the flow(s) will be run into each’s control valve to the motor..
Does this sound correct ?
Any advice that can be supplied on this application will be appreciated. Thanks
