saved section
saved section
saved section
How do I save a sketch in Pro\E then reuse it in another sketch?
RE: saved section
Try the ProE forum for better response.
RE: saved section
Hi Snewton,
In the section you wish to save, click File, save, use default name and remember it.  Then go to the new part and set up the new section you wish to create (copy to) and click sketch, data from file, chose file type .sec and you should see the section you just saved and pick it.
You will have to play around with this to get the hang of it.
Tofflemire
RE: saved section
Thanks, Tofflemire!  That worked perfectly!  I appreciate it.
