removing surface to show parts.
I've got an assy. when in an iso orientation there is a wall in the way of parts i want to show. The thing is i want to do this in the assy model not in a drawing. I've thought of creating a cut to remove the wall in that assy, but with bosses parallel to the wall, it becomes a bit involved. Is it possible to "remove surfaces" so to see whats behind it instad of just cutting a big chunk from the assy?
TIA
TIA
Adam
RE: removing surface to show parts.
Alan M. Etzkorn
Project Develpment Engineer
Wabash National Corp.
www.wabashnational.com
Adam
For now, maybe make a configuration with the wall removed?
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP2.0 / PDMWorks 05
ctopher's home site
FAQ559-1100
FAQ559-716
Chris, and as in removed you mean an extruded cut in a configuration?
Adam
Chris
ctopher's home site
FAQ559-1100
FAQ559-716
