layers switch vs cut and paste
I'm using Wildfire 2.0. Is there an easy way to switch a feature to a layer and remove that same feature from all other layers, all in one command.
RE: layers switch vs cut and paste
Did you try to create a mapkey?
-Hora
Modelcheck can do the job automaticaly. It is a bit hard to configure, but then you can batch the job over all your models easily.
JB36
Modelcheck sounds like a good idea i'll give it a try thanks
SteveVan,
Were you ever able to accomplish this using Model Check?
If so can you give me some details.
thanks
