Estimating THD of a system
Hi again,
If I have one buffer with a THD of .3% feeding another buffer with a THD of .6%, can I multiply the two numbers together to get a good estimate of the total THD?
ie 1.003*1.006=1.009 (.9% THD)
Steve.
Steve.
RE: Estimating THD of a system
Gunnar Englund
www.gke.org
Just a question, How does your formula work if you input a signal into an Ideal .3% thd amp would you not have a circuit with < .3 thd? Then that signal into a .6 Ideal amp which would add another .6 thd. This would seem to be true if the circuits were independent. If not independent ( feedback from device #2 back to device #1) then it would seem that the thd of the last device would be the determining factor. Also this would not take into consideration any thermal noise and such from other circuit components.
-elf
Not so sure what you mean. Sqrt(0.0^2 + 0.3^2) = 0.3 So the 0.3 distortion is conserved. Commutative law of multiplication implies that the order of amplifiers has no effect of outcome of the 0.3 and 0.6 THD experiment. Do you have experimental evidence saying otherwise? The sqrt(sum-of-squares) has always given me reasonable accurate results.
Regarding noise: That is a completely different question that was not covered in my answer. But, if there are several independent (stochastic) noise sources, they shall be added in the same way.
Gunnar Englund
www.gke.org
Yes your right about the question of noise, just adding to the conversation. Yes, I have no experimental evidence that would indicate your wrong on your sqrt of the sum of the squares formula. I think it just seemed logical to me that the THD's would be additive. I think that I was relating to amplication where if stage one is A=10 and Stage 2 is a=10 then the overall gain would be 100 not 14.1.
Thanks -elf
Gunnar Englund
www.gke.org
Gunnar Englund
www.gke.org
Perhaps one could say that the sqrt(sum-of-squares) gives an approximation to the likely outcome in a typical situation?
I really have to dig deeper...
Gunnar Englund
www.gke.org
All I need is just a rough estimate. I'm going to be taking a design into a lab to have some tests done, I just need a reference point so I know how far off from the ideal I am.
Steve.
