Question about 7805/7905
I'm building a system that has analog and digital circuitry. I had two questions:
1) The system includes high end audio. Is using a 7805/7905 combination for the power supply a bad idea? Are they good enough?
2) Should I seperate the digital power from the analog power? As in, should I have two seperate 7805s?
Steve.
Steve.
RE: Question about 7805/7905
1) Use +/-15V for the analogue supply rails. You will have much more signal headroom and should also get a better SNR.
2) Yes.
Consider buying a book like 'The Art of Electronics' by Horowitz & Hill. Although it's getting old these days, the principles of analogue and digital design are still sound. It is a very readable book without a lot of heavy maths. You may find some of the ICs referred to have been superceded, but finding modern equivalents should be quite easy.
If we learn from our mistakes,
I'm getting a great education!
