minimum exposed thread
I've been told that at least 3 turns of thread should be visible at the end of a bolt to ensure that the nut will maintain full tension. Can anyone explain the mechanism behind this? I'd like to know as I need to cut some bolts short in order to weld a small nut (o.d. similar to the diameter of the original bolt) to them. A transducer will then be mounted in this smaller nut.
Will the small nut provide "support" to help keep the large nut at tension?
RE: minimum exposed thread
Basically you need to ensure that the first thread on the nut is engaging with a fully formed thread on the bolt. Given typical lead-ins on bolts 3 turns seems a bit much.
Theoretically there's also the stress flow, which will be somewhat affected by the amount of bolt protruding.
Cheers
Greg Locock
-- drej --
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
In addition, every pipefitters handbook I've ever seen has tables showing the number, diameter, and length of studs for various classes & sizes of flanges, when using 2H (heavy) nuts. Many people think the tables are wrong - usually showing lengths that are FAR too long, but that's because they're using Gr 5 or 8 SAE bolts, and matching nuts, which are typically NOT approved for the service. If studs & matching heavy nuts are used, the lengths on the tables work out just fine.
thread725-57019
thread404-41951
thread725-37409
Cory
Of course drill/tap has nothing to do with the overhang allowance, but three (3) seems to be a convenient number to remember. I have never, never seen anything in the literature on it, but recall as a Junior been instructed to allow three (3) threads overhang on the nut.
It makes for a prettier AutoCad picture, but I guess five (5) full threads works just as well, aye?
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
