How best to protect mild steel in an anoxic environment?
I am going to place a mild steel structure on the ocean floor in an anoxic area to monitor Killer whales for the Institute of Ocean Sciences. I was wondering if anyone had an opinion or suggestion on how best to protect it. The structure will be submersed for 3-5 years and is mostly comprised of 4x4x3/16 box tubing if that has any bearing on the solution. Thank-you in advance for any help you can offer!
RE: How best to protect mild steel in an anoxic environment?
Incidentally, if it is oxygen free how do the orcas survive?
Steve Jones
http://www.pdo.co.om/pdo/
