Determining active corrosion on buried pipeline
In that there are numerous deposits that can be found when a buried pipeline is exposed, is there a simple test to determine if the deposit represents active corrosion?
RE: Determining active corrosion on buried pipeline
A good rule of thumb is to assume you DO have active corrosion unless some measure(s) are taken to prevent it, or the environment is benign. Assuming again that your pipe is steel/cast iron, remember that it generally wants to return to its natural form, iron oxide.
