Cropping an Exploded View
3
CADGemini (Mechanical)
I have found that many user's here that I work with are not aware of this tip. So I figured I would share it with everyone here also.
After inserting your exploded view use a square, circle or polygon to define your crop area, and then right-click. Go to properties for that view and uncheck "Show in Exploded State". Crop the view as you normally would. Right-click on the view again, go back to properties and check "Show in Exploded State".
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP3.0
