Catia V5 Display flicker on HP NW8240
Hi
   I am running Catia V5 R14 on an HP nw8240 mobile worstation. I am noticing that when I move my models across the screen whether I rotate, pan or zoom the part flickers. I am set at 1680 x 1050 and the refresh is 60Hz which is the only choice at this resolution.
Did anyone else come across this problem with a widescreen and if so what was the solution.
Dan
