How important is bolt preload?
4
For a grade 8 hex head bolt I believe the recommended preload is .90 x proof strength x bolt tensile area.  If I torque it as to develop less than the recommended preload, will that have any effect on the overall external load carrying capacity of the bolt?
RE: How important is bolt preload?
3
Hi TJK1
Pre-load for a bolted joint should be based on the external forces the bolt as tow ithstand during service have a look at this web site it should explain everything.
http://www.boltscience.com/pages/info.htm
Best regards
Desertfox
Most torque recommendations is 75
to 80 percent of the proof load
depending on how the bolt is tightened
and of what magnitude the dynamic
loads impose on the bolts.  If you
have only static loads and use a
very sophisticated bolt tensioning
device, you might consider using 90
percent of the proof load.
Preload is very important to load carrying.
www.boltscience.com has a good writeup, or try the machinery's handbook
