OLE Objects Causing Drawing To Crash
I am using CAD 2000. I am cutting and pasting cells from an excel spreadsheet into my CAD drawing. The cells go in as an OLE object. If I paste the cells onto sheet 2, the outline of the OLE shows up on sheet 1 as well. If I delete the object from sheet 1, it causes my drawing to crash. I am currently making the OLE's not selectable and that keeps them from displaying on other sheets. Any advice on what is going on would be appreciated.
RE: OLE Objects Causing Drawing To Crash
"Everybody is ignorant, only on different subjects." — Will Rogers
