Non-Common Font in Title Block--okay?
Is there any reason to shy away from using a non-'common' font in my drawings' title blocks? By non-common, I mean something that doesn't come standard with Windows (like Arial). I'm concerned with PDF output and exported DWG/DXF files--I don't want the recipient of either to get a file in which they can't read the text. Thoughts? Thanks,
Brian
Brian
RE: Non-Common Font in Title Block--okay?
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP2.0 / PDMWorks 05
ctopher's home site
FAQ559-1100
FAQ559-716
But if you export in DXF/DWG format or share SW files, then you need to send the font file to the recipients.
