How to use Transduecers?
I'm performing the ultrasound scattering simulations. As a boundary condition I need to create a pulse/plane wave. Since the elements types that I'm using do not have electro magnetic properties, I cant use "Preprocessor>Loads>Define Loads>Apply>Electric>Excitation>Planewav0>Define Wave".
But I noticed that you can use the following path to create a plane from a node.
Preprocessor>Modeling>Create>Transducers>Electromechanic>Node to Plane
the help file doesnt have relevant infromation on how to use this command. Does anyone have any insights on how to use this command or know any examples that illustrate this command.
