How to insert block in ModelSpace through VBA?
First excuse me for my english! It's posible to written stupid things some times.
 I'm using VBA for Autocad from month ago. I was written a program to put block with attribute, but the command Thisdrawing.Sendcommand dos't work and do not now why.
Please help!
RE: How to insert block in ModelSpace through VBA?
try to avoid using the Sendcommand function
take a look at the InsertBlock example in the Help files
CODE
Sub Example_InsertBlock()
    ' This example creates a block containing a circle.
    ' It then inserts the block.
    ' Create the block
    Dim blockObj As AcadBlock
    Dim insertionPnt(0 To 2) As Double
    insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
    Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "CircleBlock")
    ' Add a circle to the block
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 0: center(1) = 0: center(2) = 0
    radius = 1
    Set circleObj = blockObj.AddCircle(center, radius)
    ' Insert the block
    Dim blockRefObj As AcadBlockReference
    insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
    Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "CircleBlock", 1#, 1#, 1#, 0)
    ZoomAll
End Sub
This is a much better way to insert a block using VBA
http://www.resourcecad.com
Thank you for the help. I will attempt to avoid SendCommadn function.
