STEP assy into Pro/E part - corrupt geometry
Does anybody have a magic method of importing a STEP assembly into Pro/E, and making a part file from the information?
Although I can import the STEP assembly into a valid an solid Pro/E assembly, I then can’t import the STEP file into a Pro/E part without some of the geometry becoming corrupt and thus converting to surfaces. Are there any config settings to sort the problem out?
I have the problem in 2001 and Wildfire2.
Many thanks
Dave
Many thanks
Dave
RE: STEP assy into Pro/E part - corrupt geometry
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Do you trust your intuition or go with the flow?
