What is the difference between field output and history output?
Hi all,
 I would like to know which is the difference between Field Output Request and History Output Requests
Plese,can somebody help me?
Thanks in advance
RE: What is the difference between field output and history output?
History refers to time
corus
-Field Outputs refer to quantities distributed spatially over the whole model(e.g. stress field, strain field, displacement field , temperature field etc.).
-History Outputs refers to quantities at specific points or quantities which characterize the whole model or a region of the model (e.g. elastic strain energy, energy dissipated plastically or other such quantities).
-Both outputs may vary with time (or with load variation over a sequence of steps).
Xerf, thank you very much by your answer.
I take advantage of to ask if you would know like  defining exactly a point of mass in a node of a rigid solid
Thank in advance
You're welcome.
If you're using CAE I think you'll have to create a point rigid part , and then from "Propety" section you can define a section (for your rigid point) containing mass and inertial behavior.
If you describe your model directly in the input file then
...I guess this might be of interest for you:
-ABAQUS Analysis User's Manual
         -16.1.1 Point mass elements
Thanks xerf.
 I am going to try to do what you say to me
Bye
