HX fouling monitoring
I need to implement a monitoring of HX fouling and I need help to define parameters to control: LMTD?
thanx in advance
thanx in advance
RE: HX fouling monitoring
The LTMD is going to increase as you increase the flow rate through one side (for example) though that doesn't mean the exchanger is fouled.
Since this would apparently be an intermittent operation, it wouldn't harm the process engineer to visit the site once in a while to take some readings. Do you agree ?
