Cutting PCB
Cutting PCB
I need help in determining what type laser to use in order to cut pcb. Also how do i determine pulse rate, energy need ,etc.. Any information on laser cutting pcb and determing laser setting to use based on a certain material would be helpful.
RE: Cutting PCB
Beam Dynamics is the world's leading manufacturer of affordable laser cutting solutions for a wide range of industries.
If you call them most likely you will talk to Matthew the designer/owner. He also developed the interface software.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
