Does a dielectric union electrically isolate or avoid corrosion?
We purchased dielectric unions to help avoid galvanic corrosion between a copper nipple and steel pipe. Problem is, the unions are steel on both sides of the isolator. So now we have a copper nipple threaded to the steel union. Are there different uses of dielectric unions? Or are we using the wrong terminology? Do they electrically isolate (to avoid static charges) or do they physically isolate (to avoid corrosion)?
RE: Does a dielectric union electrically isolate or avoid corrosion?
It will isolate the two sides electrically, ie, it will not allow current flow through the piping from one side to the other, and thereby prevent galvanic corrosion.
---KenRad
