Rebar splice lengths in Structural Walls
I am designing a shear wall (in a high seismic zone), which does not require boundary elements, and have a question about the rebar splice lengths. ACI 318-02 section 21.7.2.3 states section 21.5.4 should be used to determine the splice length. Section 21.5.4 bases development length for a straight bar on a factor times the development length of a std hook. The factor could be either 2.5 or 3.5 depending on bar location. However section 21.5.4.3 states that an additional factor of 1.6 should be used if the rein is not in the confined core. Does that mean the development length for all rein in a structural wall should be multiplied by 1.6? PCA notes on ACI 318-02 example 29.6 appears not to follow section 21.5.4.3. Any advice would be appreciated.
RE: Rebar splice lengths in Structural Walls
The rebar splice length I want is for a straight bar in a structural wall without boundary elements(no confined core).
