Wave Geometry Linker
Hope someone can please help
I have just used the wave geometry linker to bring a part into an assembly to enable me to modify it. Upon activating this command I used the button to blank original.
I later realised that I did not need this part modified in the assembly, so I removed the link, but I can't seem to unblank the original item.
In the assembly navigator when I click on the component it says it is unblanked but I can't see it.
The only way I can get to see it is to use the "Replace reference set" button and select "FACET". But this still seems to be to the linked model as I can't mate anything to this file.
Please help
RE: Wave Geometry Linker
First, when you use wave geometry linker you are not "bringing in" a part. You are really creating a duplicate part in the working part file. Its feature attributes are linked to the assy part. That's how your able to modify it. Just a heads up on that one.
Are you sure its layer is turned on? (I've done that one a time or two)
Did you somehow change its reference set to exclude the solid model? (rare, but I've seen that happen...)
Bill
Thanks for the help. I've can now see the model.
