Pressure Vessel Software
My company is thinking about purchasing pressure vessel design software.  Could anyone with experience please recommend a quality program with the following capabilities:
1) Pressure vessel design (head / shell thickness etc...)
2) Wind / Seismic design
3) Leg / Lug design (vertical vessels)
4) Saddle design (horizontal vessels)
The "Advanced Pressure Vessel" program from Computer Engineering has been recommended.
Any comments are greatly appreciated.
RE: Pressure Vessel Software
Jproj,
In my experience, I have seen APV, PV Elite and Compress, in the above three software, the best software is Compress to fulfill your requirements.
Compress software is available in two versions that are Dos & Window version, and there is a lot of future available in the window version.
You can visualize the object and you can find out the fouling or classing among the pressure vessel parts and accessories, and you can relocate to avoid the fouling in the initial design stage itself.
you can find more details regarding this software in the website : www.codeware.com
Good luck
Babu
PV Engineer
Singapore
jproj:
I agree with babumathan.  I have worked with both Compress and APV and Compress is by far the more user friendly program.
Compress will analyze and help you to design saddles, support lugs, and skirts.  It produces some excellent report calculations that are easy to follow and understand.
APV is not a bad program, it just has some idosyncracies that make it user unfriendly.  I also found that Compress support was much more ready and able to answer my questions than the APV support staff.
I would definetly check out Compress at www.codeware.com and see for yourself how it compares to APV.
Scott
Ditto on the above comments.  APV is ok, but the user interface is clumsy.  I think Compress has a better user interface.
I have used Compress and it is a great program. It will do everything you need it to do.
I suggest the software "CerebroPV".
This is a new software with a best user interface, easy and friendly.
It contain all your requisites.
See www.cerebromix.com
I have experience with PVElite, Compress, Disasu, Express-m, CodeCalc etc.
I found Compress the best. PVElite also works well.
Chio,
COMPRESS IS EXCELLENT SOFTWARE. I AM ALSO USING IT.
Hi babumathan (Mechanical),ksuengrng (Mechanical), meca (Structural), SSPT (Mechanical), abdulrs (Mechanical):
Have you completed the Codeware training classes & did you get your CEU credit.
Leonard@thill.biz
www.thill.biz
