Chain Command
Chain Command
Chain Command
I am in the process of using Geopak to help obtain beam offsets for a bridge.  My question, is there a way to store and print the length of these offsets in order to have a printout at several locations?  Does this require the use of the chain command?  If so, how do I begin to set this up?  I an new to Geopak, and no one at the office seems to know a way to produce the information for printout.  Thank you in advance for your help.
