CATBench question for
I'm running CATBench in order to give a relative comparison between 2 Dell systems I have here. I'm doing this testing in the V5R14SP1HF9 version of Catia. This is the only version I have available to me. I understand that CATBench may not be optimized for this version but it should allow me to compare these 2 systems to each other accurately.
In the graphics benchmark testing there is dialog that comes up after entering c:TestVisuPerfoDraw in the Powerbar. However, this dialog no longer reports frame rate in milliseconds. All that is reported is a visualization time but no units are noted. I assume its in milliseconds. Am I safe to assume since I entered in 100 for the repeat parameter that the visualization time is for those 100 frames? Dividing by 100 is then the ms/frame value which is entered into the spreadsheet? If I use this logic, my numbers look radically different from those of other systems.
Is there someone out there who can give me some information on this?
Thanks....
Thanks....
Fighter Pilot
Manufacturing Engineer
RE: CATBench question for
Try the SPEC benchmark (www.spec.org).
Lee
http://www.lmco.com
The visualization time is still ms/frame, it is independant of the number of frames.
c:TestVisuPerfoDraw is fine to compare systems, no matter what the release.
Fighter Pilot
