Extension lines Can't turn off 1 of 2?
Hello, I am dimensioning an arc in SW2005 sp2.0 and want to show it as a dia. dimension. It throws out two extension lines and I want to turn the second one off.
I open dimesion display dialogue box and
"extension lines" "
"dispay first" is checked
"dislay second" is checked
but this part of the box is grayed out I can't pick anything? any suggestion?
Thanks in advance, Jeff
"extension lines" "
RE: Extension lines Can't turn off 1 of 2?
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP2.0 / PDMWorks 05
ctopher's home site
FAQ559-1100
FAQ559-716
Chris, I can't pick em (grayed out) meaning un-selectable.
Can you pick them on your screen?
Chris
ctopher's home site
FAQ559-1100
FAQ559-716
If you can do the single leader, but already have a double leader, the only way I know to get the single leader is to snap the dimension again and place the dimension in a different area (diagonal from center) and then move it where you want it. Then convert to a diameter dimension.
Jeff Mowry
