Tie-in H2S and SO2 containing pipework
I'm currently working on a project where H2S is removed from the proces gas by means of a Claus unit and SCOT unit.
I'm aware of the problems when making a tie-in in existing Liquid Sulfur carrying lines. However, what to do with lines that contain NO elemental Sulfur but only H2S/SO2, etc? Can I make a tie-in by cutting and welding or do I need to replace complete sections from flange to flange?
So far I have not found much literature on this subject.
greetings
S
(The Netherlands)
greetings
S
(The Netherlands)
RE: Tie-in H2S and SO2 containing pipework
~NiM
