Selection Filter Tip-of-the-Day
Did you know that you can assign a HotKey for just filtering Surfaces? There's also HotKeys available for filtering Edges only and Verticies only. Go to Tools\Customize\Keyboard Tab\Category: Others\. There you will find choices for Select Edges, Select Vertices, and Select Faces.
Also [F6] toggles the current Filer on/off.
Later,
Ken
RE: Selection Filter Tip-of-the-Day
Ken,
That is a good tip. Next time it might be good to post this as a tip instead of a question. I know I've done the same thing in the past.
Anyways thanks for the tip. I knew it was there just never bothered to use it.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP3.0
Face filters are handly for mating.
I unassign the default keys for Faces, vertices, and edges. They are too easy to accidentally turn on. I don't assign them to anything else but assigning them to "shift" keys maybe be useful.
Jason Capriotti
Smith & Nephew, Inc.
