INVOLUTE SPLINE HUB
INVOLUTE SPLINE HUB
Hi All, I need to know and or have the standard that are related with the involuted splined hub .
I' need info about the following standard related to splined shaft and hub as used in clutches in cars .
Particularly this ones:
ASA 24/48
NFE 22-144
B18-1157
01.33 001/F
I need to draw its, I have the diameters, spline qty, etc.; but I have not the splines profiles.
Maybe you can send me where I can get this norms.
Best regards
ASA 24/48
NFE 22-144
B18-1157
01.33 001/F
Best regards
RE: INVOLUTE SPLINE HUB
My old 24th Edition has 30 pages on involute splines.
Tolerance was not a problem for my task.
I cut it by laser.
Pardal
Try http://www.ili.co.uk/ , I use this site to buy all kinds of standards. Otherwise, i use www.beuth.de.
best regards
