Print resolution
Print resolution
Print resolution
I have to print a draw of a very smal part (dimensions are abt 1mm X 1mm )with SW2005 SP3
In SW windows, the draw is correct, but when i print, I have facets on circles. If i creat a print preview, I can see these facets.
- I use a general scale of 50:1
- I created High quality views
- In the document properties, quality image is set on "High"
- In the page setup, i print with a scale "100%" and "High quality" is enable.
- print option, "convert draft quality drawing views to high quality" is enable
Is there a hidden option i have not seen????
RE: Print resolution
i check my printer options, but everything is set on "high quality".
But what do you mean when you say "check the windows options" ?
Windows has printers in there, check their options. When I say printer I mean there are printers that have their own options outside of windows.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
