Midimaster Vector question
Hello. I have a Midimaster Vector Siemens inverter. I have noticed that when the inverter is stopped the frequency setpoint does not alternate with the actual output frequency as it is described in the manual. Is it something that can be done ti fix this?
RE: Midimaster Vector question
HI
I THINK THAT WHEN YOUR INVERTER IS STOPPED ie ENABLE IS OFF
YOUR REF ON. IF YOU REMOVE YOUR REF YOU SHOULD SEE THE
OUT PUT FREQUENCY DROP
  REGARDS LAUNDRY
