Expansion Joint Calculation for Oil Refinery Piping Process
I would like to know if anyone deal with CS Pipe Expansion Joint Calculation before and any reliable manufacturers in the industry? Thank you very much in advance.
RE: Expansion Joint Calculation for Oil Refinery Piping Process
http://
http://ww3.ejma.org/EJMAStandards.htm
Here is a site that will give you some in-site on the design process.
http://www.usbellows.com/ejguide/index.html
Thank you.
See
http://www
Piping Handbook at (Library?)
http://www
Comment
Be aware that the suppliers of mechanical expansion devices (bellows etc.) are interested in selling ($) you there device – which may be necessary due to space limitations etc. These devices may require periodic maintenance ($).
Expansion pipe loops might be less expensive and should require no maintenance – if you have the room.
Expansion Joint Systems, Inc.
http://www.ejsus.com/
Senior Flexonics Pathway
http://www.myej.com
Good luck,
NozzleTwister
Houston, Texas
1. What type of expansion joint?
2. What specifically are you trying to calculate?
3. Thermal expansion in a piping system that is to be accommodated by an expansion joint?
4. Anchor loadings resulting from expansion joints installation?
5. Guide requirements for expansion joints?
6. Cyclic life of expansion joints?
7. Stress in an expansion joint bellows?
8. Why Br. units instead of metrics?
9. Do you have a problem with unit conversions?
Can you be specific with your question?
