Efficient method of attaching/tightening hydraulic holes.
I am redesigning at a process that uses open-ended wrenches to tighten hydraulic hoses. I have tried to use some ratcheting wrenches, however due to space issues this has had little success.
RE: Efficient method of attaching/tightening hydraulic holes.
The bigger problem is stopping leaks especially in SAE fittings. Face seal fittings are not as problematic.
