Problems with Feature Driven component pattern
I am having some trouble using the feature driven component pattern. I have used it in the past with no problems, but now it is really screwing up. I have a sheet metal part with about 20 holes, all the same size, and made with the hole wizard. I insert 1 pem nut into the part. I then use the pattern component wizard, pick the pem as the seed, then the driving feature is the hole. The problem is that it insert all the parts in the drawing, but none of them are in the holes...they are all offset from the part, but in the right location relative to each other.
BTW, I am using 2005 SP3.0
RE: Problems with Feature Driven component pattern
Ken
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
So simple. All this time right there in front of me and I never saw it. That's a Star for you.
Ken
Regg
