Product not visible - huge Problem
V5R14SP3
I'm using a macro which creates a new CATProcess from a template and then loads a CATPart into the product. The user chooses the files via FileSelectionBox.
Problem is:
Nothing beside the MfgAxisSystem is visible. You cannot see the part nor the safety planes (noshow is empty). But you can select the part and use it for further operations. After saving and reopening the CATProcess everything seems to be fine (= all is visible).
Any ideas?
