Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...this web site is a 'Godsend' for me. If I have a programming problem that I'm unable to solve, I'll get a sensible reply in no time. It's really great!..."
Geography
manal72 (Electrical)
24 May 05 3:20
I have some confusion about the defintions , header files, how to make them can I make  them just by saving them on a C++ compiler ,  is an Application program interface API a way to have serial port communication really I am confused plz help
bkeith (Computer)
26 May 05 17:30
You can make a header file in notepad if you want and save it as whatever.h
Probably you have header files that provide the function defintions for serial port communication.
bkeith
Coastal Instruments
Mass Flow Contoller Specialists
johnwm (Computer)
26 May 05 18:27
<off-topic>
bkeith
Are you aware that the second link in your sig currently points to Google?
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
UK steam enthusiasts: www.essexsteam.co.uk
umn (Electrical)
2 Jun 05 4:47
First, let us know which compiler you are using. Bet to give you some idea:
- Most compilers come with standard libraries that make it very easy to configure and use serial communication.
- The APIs are declared in corresponding header files.
- If you have to use a specific API, you 'include' the corresponding header file in your .c or .cpp file and then use these functions to open, configure, read from/write to, and close the serial port. (a common example: to use console IO including keyboard inputs, I would include conio.h and while compiling, see that that the library path for compilation includes the standard library libc.lib)
Hence, more information is required to give specific suggestions.
[um.narayanan@gmail.com]
Close Box
Join Eng-Tips® Today!
Join Us             Close
