PDMworks 2005 help wanted
2 questions,
is it possible to do a "batch" or "bulk" check in for legacy drawings into the PDM client? if so how?
and my last question is as a vault administrator when adding projects, is it possible to add sub-project? if so how?
RE: PDMworks 2005 help wanted
It is only possible to bulk check in drawings though Vault admin. There is an option "Create/use subprojects for subfolders" tick it to automatically add sub projects.
When we did our bulk check-in, all of the files I checked in as "owner" changed the "drawn by" in our title block to my login name. Same with my coworkers. Don't know if this is a problem with PDM, or an error in the macro that runs our title block info. Has any other PDM user had this problem?
Yanceman.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP2.0 / PDMWorks 05
ctopher's home site
FAQ371-376
FAQ559-1100
