Need QFH antenna
Need QFH antenna
I need a QFH antenna for a small handheld device using 900MHz. Anyone know of a site that sells this?
erik
erik
RE: Need QFH antenna
kch
Higgler, IIRC, the QFH antenna has better circularity than a turnstyle crossed dipole type antenna. Besides that, I too would ask why a QFH?
The QFH is circular off the end of the antenna, but not in other directions. This would indicate that the antenna is meant for space communications. The QFH receives vertical and horizontally polarized signals off the side equally poorly. For terrestrial communications where faraday and spacecraft rotation are not factors, linear polarization would seem a sure bet...unless there are problems with multipath, then the 20 dB cross polarization(Left hand circular to Right hand circular) advantage would come into play.
So, Erik, care to let us in on your need for CP?
I remain,
The Old Soldering Gunslinger
